juaky
Mar 20, 2017Aspirant
FS Check stuck at 46%
Hello I got a bunch of alerts the other night and dont know what to do at this point. do i leave it checking the files? I have XRaid 4GB. Alll drives were upgraded a few years ago. here i...
mdgm-ntgr
Mar 20, 2017NETGEAR Employee Retired
Is your backup up to date?
Sounds like you could have one or more bad disks.
- juakyMar 20, 2017Aspirant
Actually yes i do belive so. I need to double check though but i relly want to see if the nas will come up.
- mdgm-ntgrMar 20, 2017NETGEAR Employee Retired
If the filesystem check doesn't progress and remains stuck you could try skipping the volume check (a boot menu option) and downloading your logs and having a look at those.
Thats what i was thinking. Should i leave it running another day?
