horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
gyroscopes
Jan 14, 2013Aspirant
I have NVX which has been fine for years. A hard drive started to cause problems (error rate increase). I fitted a new hard drive and the volume was expanded. I started to get problems with the NVX hanging on some directories. A volume check resulted in a huge number of errors listed. Now the volume won't mount. Netgear support just say the volume won't mount and offered to assist with factory resetting.
95% sure there is a software bug.
5.5TB lost. Just about to see if I can mount the drive.
How did you mount in read only mode?
