horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
horshack
Jan 24, 2013Aspirant
For anyone lurking. We're now up the the point of collecting data for developers to look at. We've performed yet another factory reset, gathering logs after the unit builds the initial volume, right after a reboot w/fsck, and then right after the first expansion + reboot w/fsck (this is where fsck fails).
The last bit of sanity checks being performed at the moment is a series of memory tests just to make sure the memory is not the problem. Of course, if there was a memory problem, I would have expected it to surface during the 4TB initial volume build and not only during the 1TB expansion.
As you can see, this has taken a long time to get to this point. I normally would have just given up and tried an older firmware to get this running again, but if there is an actual problem in the 4.2.22 firmware, it would be nice to find and have fixed in a later release.
