horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
horshack
Feb 04, 2013Aspirant
Support says, "Developers found that initial file system scan make file system corrupted."
I'm not really convinced. It doesn't sync up with all the bad behavior before I started debugging. My best guess is it's either a bug in FSCK or it's a bug in the expansion process/tools that are corrupting inodes.
