horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
JohnnyB11
Feb 16, 2013Aspirant
horshack wrote: Note these all worked. Supposedly 4.2.23 will fix the expansion problem
Thank you for your efforts, again! At least, my volume expanded using 4.2.22 did not die the last weeks and checking the md5sums of all files shows no silent data corruption.
