horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
mdgm-ntgr
Apr 09, 2013NETGEAR Employee Retired
You should open a NetGear support case (see Online Submission link in my sig) and post your case number.
I have been informed that NetGear is looking into this issue at the moment. Any solution provided in 4.2.23 though would be if possible to prevent users who have yet to run into this issue (i.e. have not yet expanded their volume on affected firmware) from running into this issue.
It is a good precaution to backup your data regularly, and particularly before doing things like expanding your data volume.
Keep an eye on the 4.2.23 beta thread: http://www.readynas.com/forum/viewtopic.php?f=51&t=70385
NetGear has already resolved a number of other issues with 4.2.22 in the 4.2.23 beta builds available so far.
