horshack
Jan 08, 2013Aspirant
FSCK Fails after expansion on NVX case# 20304759
I have an NVX that has given me some FSCK problems lately. It started with an expansion months ago that caused FSCK failures, so all the data was backed up, the NVX reset and rebuilt, and then all th...
Leia
Apr 09, 2013NETGEAR Employee Retired
Hi guys, we upgrade the ext2/ext3/ext4 file system utilities - e2fsprogs in 4.2.23 T build, so it's fixed now. Please do not expand volume in 4.2.22. Just wait 4.2.23.
And the bug is only in NVX, 32 bits system. Ultra & Pro serials, 64 bits system have no problem.
Thanks.
-Leia
Thanks.
-Leia
