getyogrooveon
Mar 12, 2014Aspirant
FTP access "ECONNREFUSED"
I have setup ftp service on my readynas 102 (latest firmware). I can log in with the created ftp user from the local network using the internal ip and is set to you port 5000 and everything is work...
getyogrooveon
Mar 13, 2014Aspirant
If I disable passive mode then that error goes away, however it is replced with the following error in the client:
500 illegal port command
The line above the error in the log shows:
Port 192.168.0.119,146,92
Thanks for help so far, much appreciated
