Fireblade69
Dec 13, 2014Aspirant
FTP Settings
Hi all I'm really struggling with trying to set up my FTP settings for my READYNAS NV+ v2. The settings on the ReadyNAS are:Enable FTP Port: 21 Authentication Mode: User Allow Upload Resumes:...
Dec 15, 2014Guru - Experienced User
The FTP server needs to be passive, otherwise you won't be able to access the NAS if your client is behind a firewall (even with port forwarding).
It sounds like something isn't right with the Asus port forwarding. Did you delete the original forwarding of 51000 to 21?
Also try testing with http://www.canyouseeme.org/ and see if 51000-50010 show up open there.
...On my router which is a Linksys AC1900 EA6900-ME
Port forwarding
External Port: 21
Internal Port: 51000
