GaWd
Oct 18, 2016Luminary
FTP will not start
Hello All, My very lightly used ReadyNAS Duo is giving me some trouble. I disabled FTP some time back as the NAS was in a public place, and now that's I've brought it home with me, I'm in need of...
- Oct 19, 2016
Hi Jenn!
I rebooted earlier in the day and it didn't make any difference. There were errors about tcp/bind but I had no idea what caused the port to be occupied. So I upgraded the firmware and rebooted and when it came back up, it worked.
JennC
Oct 19, 2016NETGEAR Employee Retired
Hello GaWd,
Sorry, I got confused there, did you reboot and it did not resolve before you updated the firmware?
GaWd
Oct 19, 2016Luminary
Hi Jenn!
- JennCOct 19, 2016NETGEAR Employee Retired
Hello GaWd,
I see. It must be the old firmware's FTP had problems.
- JennCOct 24, 2016NETGEAR Employee Retired
Hello GaWd,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
