eton
Jan 28, 2013Luminary
FTPS access over WAN?
Setting up a FTP connection over WAN to a ReadyNAS device can be very tricky. After some time I found a solution and posted it here. But I have noticed that it's possible to login over FTPS locally, ...
eton
Can anyone see what's causes this and what's wrong?
On of the more interesting parts is, FTPS over WAN tls.log:
This was interesting: http://www.proftpd.org/docs/howto/TLS.html
Jan 28 15:45:20 mod_tls/2.4.2[29939]: TLS/TLS-C requested, starting TLS handshakeHow come that TLS can establish handshake locally but not from outside?
Jan 28 15:45:20 mod_tls/2.4.2[29939]: unable to accept TLS connection: received EOF that violates protocol
Jan 28 15:45:20 mod_tls/2.4.2[29939]: TLS/TLS-C negotiation failed on control channel
Question: How do I generate the certificate files used by mod_tls?
Answer: The mod_tls module uses the same certificate files as Apache's mod_ssl. The mod_ssl documentation explains what the files are, how they are used, and how to generate your own: http://www.modssl.org/docs/2.7/ssl_faq.html#ToC28
