eton
Jan 28, 2013Luminary
FTPS access over WAN?
Setting up a FTP connection over WAN to a ReadyNAS device can be very tricky. After some time I found a solution and posted it here. But I have noticed that it's possible to login over FTPS locally, ...
eton
Argh. My WAN refernece client doesn't seem to ask for certificate. I will try to ad it manually. But, hey it works over LAN, this might not be the cause for connectivity problems. Where does ReadyNAS store the default certificate?
