eton
Jan 28, 2013Luminary
FTPS access over WAN?
Setting up a FTP connection over WAN to a ReadyNAS device can be very tricky. After some time I found a solution and posted it here. But I have noticed that it's possible to login over FTPS locally, ...
Jan 29, 2013Guru - Experienced User
If you have an FTP proxy on the path or if the router firewall is protocol-aware then that could certainly create an issue. I use non-standard ports for WAN access, and the routers on the path are simply forwarding.
