CPNY80
Apr 08, 2018Follower
Garbage products
just doesnt work never has, i can never log in, the whole thing is garbage. waste of a few hundred bucks. apple is easy. should have bought a crapple product. junk junk junk
Sandshark
Apr 09, 2018Sensei
CPNY80 wrote:just doesnt work never has, i can never log in, the whole thing is garbage. waste of a few hundred bucks. apple is easy. should have bought a crapple product. junk junk junk
Or maybe you should have purchased a current model instead of one that was discontinued several years ago (assuming listed model number is correct). Since you obviously purchased it used, you may have purchased junk -- but not because it was built as such. Or, there could be an operator headspace issue.
You are likely having trouble because of increased security implemented on SMB (Windows network protocol) and HTTPS in the years since that NAS was a current model. There are work-arounds for them. But without details and an attitude adjustment, you're unlikely to get any assistance.
But I'll give you the first clue: You can't do anything without a hard drive installed.
