CPNY80
Apr 08, 2018Follower
Garbage products
just doesnt work never has, i can never log in, the whole thing is garbage. waste of a few hundred bucks. apple is easy. should have bought a crapple product. junk junk junk
schumaku
Apr 29, 2018Guru - Experienced User
walshlink Hurry up - Apple does abandon the "simple" (trust me: hard or not manageable) routers and storage devices - AirPort Extreme, AirPort Time Capsule and AirPort Express were mostly ignored by Apple and devices are only available as long as supplies last. Support is retained for five years.
If it would be so easy to be in this router and storage market, Apple would have continued to bring up2date systems and K.I.S.S. in the way you expect it. Obviously it's not as easy as you draw the blue skies picture on your little Apple cloud.
Ref. ReadyCloud - this is the section you posted in: ReadyCloud does require ReadyNAS OS 6, your legacy ReadyNAS is not supported.
