HolgerGT86
Feb 26, 2021Guide
Gbit Ethernet Flow Control on RN104
Hello Community, I have a question to my ReadyNAS RN104 running at FW level 6.10.4. When I look into the network interface settings, there's no information about flow control for Gbit Ethernet adap...
- Feb 26, 2021
HolgerGT86 wrote:
I cannot figure out if flow control is enabled or disabled.
Is there a way to find this out?
You have to use ssh (ethtool). I see this on my RN102:
root@RN102:~# ethtool eth0 Settings for eth0: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Half 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Link partner advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Link partner advertised pause frame use: Symmetric Link partner advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: external Auto-negotiation: on Supports Wake-on: g Wake-on: d Link detected: yesThis says that pause frames (ethernet flow control) are not supported. FWIW, it is supported (and enabled) on my x86 ReadyNAS.
Feb 26, 2021Guru - Experienced User
Settings for eth0:
1000baseT/Full
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 0
Supports Wake-on: g
Wake-on: d
Link detected: yes
