NAS_ARGH's avatar
NAS_ARGH
Generate a certificate????!!!!?!?!?
How in the world can one generate a security certificate with this Hunk of Junk!
I have a Readynas NV+ 2V (ARM) and it does not have this Frontview that everyone says will generate the certificate. I am stuck with the Godforsaken Dashboard. Latest firmware RAIDiator 5.3.9
When you set it up it takes a DHCP assigned IP address and it will want to cling to that IP address come hell or high water! I set the unit to my static IP address... and also in the HTTP and HTTPS section as well, press "Apply" and it's just as well I do something vulgar with my thumb... because I exit, go back, and the cert is still for the original DHCP assigned address again! I have searched, and searched, and searched and nowhere can I find the answer to what SHOULD be a very very simple fix.
I have since reset the thing to factory defaults, and tried again, figuring the thing was corrupt. not a chance - I suffered out the numerous hours of re-syncing the drive, but alas... it did it again and while the IP address is a now a new DHCP assigned address, it's still not what I want - so I change it back to the static one I want, and again no way to generate a certificate with the correct IP address!!
I am totally frustrated, and truly regretting buying Netgear!
  • Hi Marto,
    Not sure how this helps because the NAS unit here is NV+ v2 (running 5.x firmware, not OS6).
    The problem is the NV+v2 does not have the ability to generate a certificate at all as far as I know, whereas the Duo/NV+ v1 does have this capability.
  • StephenB's avatar
    If you can connect with https then the v2 is creating a self-signed certificate. It might not let you re-create it easily, but it is creating one. The v1 certificate is also self-signed of course. The implication of "self-signed" is that the certificate provides encryption, but it is not useful for authentication.
    Did you try the two procedures?
    If you access the NAS two ways (say by its IP address and over the internet using ddns) you will need to install the certificate twice.
    Note if you use FireFox you can just store the security exception, which is easier.
  • Yes I have the exception added to my Firefox, so that's good.
    The NV+ v2 is certainly presenting a certificate, but with the default IP address of 192.168.168.168, but this leads me to believe it is not creating a certificate for the NAS configuration.
    Understood.
    I'm not suggesting that a self-generated certificate with specific IP address is effectively any different to the generic one, merely that it appears to be static, whereas with the Duo v1 it could be created.
  • Certificates are kinda tricky to get by.
    If you want to avoid the warning you need :
    - to have a certificate that fits the IP/hostname of the NAS.
    - to make sure that certificate has been approved by a certification authority
    - to add the certificate authority to your trusted list
    - to check certificate authority with another one
    To generate a self signed certificate you can do this via SSH via openssl, there are plenty of tutorial on internet to do so. If you want your certificate to be accepted without question, use a certificate from verysign or thawte but that's not cheap. If you want all your home certificate to be accepted you could set an certificate authority, but that's quite a hassle just to avoid checking "always accept" the certificate in safari or firefox...
  • StephenB's avatar
    I think aks is just wanting a control which regenerates the self-signed cert to matches its current IP address.
    It's not something I care about myself (I haven't bothered to regenerate the certs on any of my NAS, and they are all mismatched with their reserved IP addresses). Since I access the NAS both over the internet and locally, the IP mismatch warning in the browser is going to happen sometimes anyway.
    As far as creating the exception - "always accept" is easy to do in FireFox, but it's not so simple with IE or Chrome. Marto73 posted the procedure for them a few couple of posts up, and is looking for feedback. Though the articles include a little OS6 stuff, most of the material is on the mechanics of getting IE/Chrome to trust the NAS self-signed cert. That applies to any ReadyNAS.
  • You could setup two web servers with two certificates, but as said before that's an unnecessary hassle.
    I personally use safari for mac which has the same option.
  • Yes I just add permanent exception in Firefox, some folks use Chrome which is a bit more of a hassle to set up. I saw the instructions by Marto73 they look quite involved, and I appreciate that is down to the browser.
    My real question is does it make a jot of difference have a self-signed certificate that matches the IP address of the NAS, rather than a random IP address? It seem not.
  • A certificate is either valid or invalid. So no if it´s not perfect there is no difference.
    As for the browser, that´s a shame chrome doesn´t have such a basic function but that´s up to google to implement that.
ProSupport for Business
