Lithium-Admin
Sep 16, 2012Novice
Getting "increasing command timeouts" error on SMART
Hey Guys, Do I need to worry about this: "Detected increasing command timeouts[65539] on disk 2 [ST31000340AS, 9QJ1AFDD]. This often indicates an impending failure. Please be prepared to replace t...
gibxxi
Sep 16, 2012Guide
Are the drives the same make/model and running the same firmware?
You could try increasing the Spindown time to something like 30 minutes and see if that has an effect. Otherwise, power down the NAS normally and remove the drive and Run SeaTools on it. That will give you a thorough diagnosis of the state of the drive. Be prepared for a bit of a wait though, as the Disk surface scan in SeaTools is mind numbingly slow in my experience.
Remember to mark which bay the drive came from too and don't get that order mixed up.
- Jan 17, 2024Retired_Member
