Lithium-Admin
Sep 16, 2012Novice
Getting "increasing command timeouts" error on SMART
Hey Guys, Do I need to worry about this: "Detected increasing command timeouts[65539] on disk 2 [ST31000340AS, 9QJ1AFDD]. This often indicates an impending failure. Please be prepared to replace t...
Oct 24, 2012Guru - Experienced User
Did you ever run the full disk test (from the boot menu)?
toomanybarts wrote: I had disk spindown set at 15 minutes on a ST32000641as nad got the same error but with 4295032833 command timeouts!!!
I took disk out and ran sea tools on it - every test they have on there and it passed everything - should I be concerned and should I push Seagate to accept the disk back (my warranty is still valid til 2014)?
You also might want to confirm the SMART tests on your PC. Acronis Drive monitor is one freeware download that will let you see them. Seatools won't.
Returning the drive to Seagate would just get you a refurbished replacement. If the NAS is performing normally I'd wait.
- Jan 17, 2024Retired_Member
