Lithium-Admin
Sep 16, 2012Novice
Getting "increasing command timeouts" error on SMART
Hey Guys, Do I need to worry about this: "Detected increasing command timeouts[65539] on disk 2 [ST31000340AS, 9QJ1AFDD]. This often indicates an impending failure. Please be prepared to replace t...
HERBIEO
Oct 25, 2012Aspirant
toomanybarts wrote: not sure what you mean "full disk test from boot menu"
Disk test. Performs an offline full disk test. This can take 4 hours or more, depending on the size of your disks. Any problems are reported in the RAIDar discovery tool.
To access the boot menu: for NV+ v2
1. Power off your unit.
2. Using a straightened paper clip, press and hold the Reset button.
3. Press the Power button to power on the unit.
4. Continue to press the Reset button until the status display screen shows an boot menu message.
5. Press the Backup button to scroll through the boot mode options.
6. Press and release Reset button to confirm your boot menu selection.
- Jan 17, 2024Retired_Member
