Lithium-Admin
Sep 16, 2012Novice
Getting "increasing command timeouts" error on SMART
Hey Guys, Do I need to worry about this: "Detected increasing command timeouts[65539] on disk 2 [ST31000340AS, 9QJ1AFDD]. This often indicates an impending failure. Please be prepared to replace t...
Lithium-Admin
Oct 25, 2012Novice
StephenB wrote: You will not get new drives, they will be refurbished. They also do not guarantee the same drive model.
honcho wrote: I connected ST31000340AS to my PC Desktop running Windows Home Server 2011 and ran the SMART report on the 2 drives and one was "FAILING" and the other was giving me "WARNING" of impending failure. I did the online warranty & return on seagate.com and getting replacement drives tomorrow. I figured why not just get the drives replaced since I'm under warranty. You should probably do the same.
Yup, this is correct.
- Jan 17, 2024Retired_Member
