DraperT
Nov 09, 2016Aspirant
Getting \\NAS-05-7A-F1 is not accessible error
Hello, I have a ReadyNas Duo RND2210-100NAS that I have been using with no problem. I have a new Asus gaming ( not a gamer) laptop running windows 10. When I click on my nas drive to access it I ge...
- Nov 09, 2016
There are a couple of things to check on the ASUS first
1- check that the network connection is "private"
2- check that the Asus workgroup (not the homegroup) is set to the same workgroup of the NAS.
3-check that you can log into the NAS admin page from the new laptop.
There is one thing to check on the duo - and that is whether you are in "share security mode" or "user security mode". If the NAS is in share security mode, you should switch it to user security mode. Here's a guide on switching to user security mode: http://readynas.sphardy.com/2010/09/how-to-migrate-to-user-security-mode_4917.html
Note that if you don't have a "security mode" choice when you click on the security menu option in Frontview, then you are already using "user security mode".
After that's done, if you still have the problem try this test:
Open CMD from the windows bar and enter
net use * /delete
net use t: \\NAS-05-7A-F1\C /user:admin nas-admin-password
Use the real nas admin password. These commands are fussy, so make the slashes are in the right directions and spaces are in the right places.
The first command just closes any existing file-sharing sessions (and there might not be any). The second attempt to mount the C volume of the NAS as drive letter T: on your PC.
If the second command fails, try both commands again, but use the IP address of the NAS instead of NAS-05-7A-F1
If these commands work, then what you need to do is open the windows credential manager on the ASUS. You'll delete any existing credentials for the NAS (again there might not be any), and create a new credential that includes the username/password of a user account on the NAS. If you don't have any, then you can use "admin".
Nov 09, 2016Guru - Experienced User
net use * /delete
DraperT
Nov 12, 2016Aspirant
This did the trick. I don't understand why I had to go through this. I did not have this problem when I got my last laptop. Thank you!
- FramerVNov 13, 2016NETGEAR Employee Retired
Hi DraperT,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- Jan 17, 2024Retired_Member
