h_tsopelas
Aug 03, 2015Aspirant
Hard disks Raid 1
I would like to ask something... maybe for someone will be silly... My readynas 102 has 2-bay. I have put 2 hard disks and at the system menu and then in volume i see with green line "X-RAID" and...
- Aug 03, 2015
Yes in Xraid with 2 disks you will have a raid 1 (mirrored) volume. If 1 disk dies or is removed the volume is still accessible.
This is does not mean you do not need a backup of the data on the volume. There are events that can lead to data loss that raid does not protect you against.
vandermerwe
Aug 03, 2015Master
- h_tsopelasAug 03, 2015Aspirant
So the other volume will have all my files? If i understand anything i save to the first volume automatic save also to the second volume?
- vandermerweAug 03, 2015Master
They are not really 2 volumes, it is one redundant volume. If you were to remove or lose a disk, the volume data is intact but the volume is then unprotected. You would still be able to access all your data.
i must reiterate that you must also backup the data on the volume to at least one other device, preferably also offsite or into the cloud.
