rmurgz
Mar 22, 2017Tutor
Hard drive failure during rebuilt - next steps?
Hi there, I have just undertaken an upgrade of the hard drives in my ReadyNAS314 as follows: * Bays 1 & 2 - 2 x 6TB WD Red Pro - to remain the same * Bays 3 & 4 - 2 x 2TB WD Red Pro to 2 x 6TB ...
mdgm-ntgr
Mar 22, 2017NETGEAR Employee Retired
Send in your logs (see the Sending Logs link in my sig)
- rmurgzMar 22, 2017Tutor
Thanks for getting back to me. Will be with you in next 5 minutes.
:smileyhappy:
- mdgm-ntgrMar 22, 2017NETGEAR Employee Retired
Looks like a bad disk to me. I can see I/O errors.
Is your backup up to date?- rmurgzMar 23, 2017Tutor
Hi mdgm,
Back-ups are up to date though I'd rather not restore from them as it's a bit messay.
Am not sure in which log you're seeing the I/O errors.
When I looked at the logs on the ReadyNAS portal it looks like the NAS had finished resyncing with the new drive in bay 3 before the drive in bay 1 failed. Am I safe to stick a new 6tb drive into bay 1 to restore my RAID5 failover or are there bigger issues that have been in play for longer?
Apologies in advance if these questions seem dumb :( and thanks again for all your help.
