rmurgz
Mar 22, 2017Tutor
Hard drive failure during rebuilt - next steps?
Hi there, I have just undertaken an upgrade of the hard drives in my ReadyNAS314 as follows: * Bays 1 & 2 - 2 x 6TB WD Red Pro - to remain the same * Bays 3 & 4 - 2 x 2TB WD Red Pro to 2 x 6TB ...
rmurgz
Mar 23, 2017Tutor
Hi mdgm,
Back-ups are up to date though I'd rather not restore from them as it's a bit messay.
Am not sure in which log you're seeing the I/O errors.
When I looked at the logs on the ReadyNAS portal it looks like the NAS had finished resyncing with the new drive in bay 3 before the drive in bay 1 failed. Am I safe to stick a new 6tb drive into bay 1 to restore my RAID5 failover or are there bigger issues that have been in play for longer?
Apologies in advance if these questions seem dumb :( and thanks again for all your help.
dmahon1
May 29, 2017Aspirant
Looks like you got lucky, the RAID is viable but degraded, and can indeed just swap your remaining new drive with the failed drive 1.
