claytonb
Apr 05, 2016Aspirant
Hard Drve Failure
I got an email notification this morning saying "Disk test failed on disk in channel 2, model WDC_WD4000F9YZ-09N20L0, serial WD-WMC1F1268766." But NETGEAR RAIDar diagnostics shows the drive is heal...
- Apr 10, 2016
I have already replaced drive 2 with a spare 4TB and all is back to normal, if another drive fails I think it's best I look for a different drive and will replace the next failed 4TB drive with either a 6TB or 8TB drive.
I don't know where I would backup 6TB of data too? one at a time every week should do it and I'll bite the bullet and go for 8TB drives, model Seagate ST8000VN0002 US$550 each with a 5yr warranty.
Apr 08, 2016Guru - Experienced User
Since your raid array is degraded, begin by doing a backup.
The fastest way would actually be to do a fresh install with the new disks all in place.
The alternative is to begin by inserting the 6 TB drive into the slot 2 (e.g., replace the drive that failed). Wait for rebuild, and then hot-remove/insert drives one at a time (waiting for full resync in between).
claytonb
Apr 10, 2016Aspirant
- claytonbApr 10, 2016Aspirant
$350 is for the ST8000AS0002 here in NZ
- mdgm-ntgrApr 10, 2016NETGEAR Employee Retired
SeaGate archive disks are not recommended for use in a NAS.
- claytonbApr 11, 2016Aspirant
I know that, I was just comparing prices, I can not find any ST8000VN0002 for around $350 anywhere
- StephenBApr 11, 2016Guru - Experienced User
Current US Amazon pricing is $348.99. http://www.amazon.com/Seagate-SATA-Cache-Drive-ST8000VN0002/dp/B01BBKYNJG
