pingjockey
Sep 11, 2016Tutor
Hard hang on 214
Had a very pecular issue on the 214 today. I plugged in an external drive and the NAS became non-responsive and I had to power cycle it. It's now in the middle of a resync but I was wondering if I ca...
pingjockey
Sep 11, 2016Tutor
I didn't get a chance to snap a pic but it was something regarding mcpu count or something. I am running 6.5.2 currently...
mdgm-ntgr
Sep 11, 2016NETGEAR Employee Retired
Was it _percpu_counter_add?
That error message could come from anywhere.
Can you send me your logs (see the Sending Logs link in my sig)?
- pingjockeySep 11, 2016Tutor
That sounds like it might have been the error, I will send the logs over to you now.
The logs have been sent, I had a look at them and I couldn't find anything that stood out. The only real bummer is that my array is resyncing which will take hours but I suppose it could be worse.
Thanks for your help!
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
Which apps are you running?
It appears you use a USB disk with this NAS at times?
