pingjockey
Sep 11, 2016Tutor
Hard hang on 214
Had a very pecular issue on the 214 today. I plugged in an external drive and the NAS became non-responsive and I had to power cycle it. It's now in the middle of a resync but I was wondering if I ca...
mdgm-ntgr
Sep 11, 2016NETGEAR Employee Retired
Was it _percpu_counter_add?
That error message could come from anywhere.
Can you send me your logs (see the Sending Logs link in my sig)?
pingjockey
Sep 11, 2016Tutor
That sounds like it might have been the error, I will send the logs over to you now.
- pingjockeySep 11, 2016Tutor
The logs have been sent, I had a look at them and I couldn't find anything that stood out. The only real bummer is that my array is resyncing which will take hours but I suppose it could be worse.
Thanks for your help!
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
Which apps are you running?
It appears you use a USB disk with this NAS at times?- pingjockeySep 12, 2016Tutor
I have plex, netgear photo and advanced smb enabled. I was trying to setup an external USB disk for backups yes.
