pingjockey
Sep 11, 2016Tutor
Hard hang on 214
Had a very pecular issue on the 214 today. I plugged in an external drive and the NAS became non-responsive and I had to power cycle it. It's now in the middle of a resync but I was wondering if I ca...
pingjockey
Sep 11, 2016Tutor
That sounds like it might have been the error, I will send the logs over to you now.
pingjockey
Sep 11, 2016Tutor
The logs have been sent, I had a look at them and I couldn't find anything that stood out. The only real bummer is that my array is resyncing which will take hours but I suppose it could be worse.
Thanks for your help!
- mdgm-ntgrSep 12, 2016NETGEAR Employee Retired
Which apps are you running?
It appears you use a USB disk with this NAS at times?- pingjockeySep 12, 2016Tutor
I have plex, netgear photo and advanced smb enabled. I was trying to setup an external USB disk for backups yes.
