PWS442
Jun 11, 2013Guide
Hard to open drive bay on ReadyNAS NV+
I had to replace one of the 4 drives two months ago. For the life of me, I could not depress the button enough to get the lever to pop out. I ended up using a 11/32 inch nut driver and applied far, fa...
Jun 11, 2013Guru - Experienced User
Inserting something at point B works best for me. The pushpin into "A" often requires a lot of force (and I have bent the pushpin trying it).
Also, there are newer trays with a square latch (http://kb.netgear.com/app/answers/detai ... pro-series) that work much better. However you do need to be careful that you get one for the pro/nv+ line - the rack mount trays, and the new RN1xx/RN3xx/RN5xx trays are not compatible.
