Daimo73
Mar 02, 2022Aspirant
Hardware Failure ReadyNas Ultra 2 (RNDU2000) swapping drives into a Ultra 4?
Hi, We had a power failure and now my Ultra 2 powers up but theres is no disk activity (leds not lit) and its undescoverable. Cant power down pressing the power button, just stays on. So I ...
Mar 03, 2022Guru - Experienced User
FWIW, you can also directly migrate the disks to a Pro or Ultra Plus platform.
Daimo73 wrote:
in the hope i can just hard swap by drives accross to retain all user settings and data.
Do you need to offload data?
BTW, if you purchase a used X86 OS-6 NAS, you can mount the Ultra volume as read-only. After off-loading you can complete the OS-6 setup, and then restore the data from the backup. So that is another option.
Sandshark
Mar 03, 2022Sensei
If you power up with no drives, does RAIDar report a "No disks" status, or is it unreachable?
It could be just the power brick, and replacements are cheap, so it might be worth a shot.
