Daimo73
Mar 02, 2022Aspirant
Hardware Failure ReadyNas Ultra 2 (RNDU2000) swapping drives into a Ultra 4?
Hi, We had a power failure and now my Ultra 2 powers up but theres is no disk activity (leds not lit) and its undescoverable. Cant power down pressing the power button, just stays on. So I ...
Daimo73
Mar 04, 2022Aspirant
Could there be an issue if the drives / data is encrypted?
I went to a computer repair mob today to try another power supply as Sandshark suggested could be the quick fix and unfortunately thats not the issue, but they took the drive and hooked it up and said the data was encrpypted and swapping it to another readynas wont help??
Is this true?
I dont know what they hooked it up to, likely just a spare bay in a computer.
Mar 04, 2022Guru - Experienced User
Did you encrypt the volume? (If you don't recall, then you almost certainly didn't). If you did, you'd have a USB encryption key connected to the NAS.
A Windows PC wouldn't recognize the format unless linux tools were installed.
- SandsharkMar 04, 2022Sensei
If the data volume is encrypted, the NAS still boots to a "waiting for ther key" state since the OS partition isn't encrypted. So that doesn't sound like a match to your symptoms (though it does sound like maybe you should find a new computer shop).
