Notreadyyet
Mar 16, 2018Aspirant
Have no connection with Ready NAS
We installed new router in the office and after the installation we lost connection with our ReadyNAS. We tried to reboot the devices: server, modem and router. It didn't help.We steel have no acces to the server. When I try to enter the server IP address in the browser
the page can't be reached.
Does your new router use 192.168.0.x addresses?
If not, you have a couple of options:
- do an OS reinstall - which resets the NAS to use DHCP, and also resets the admin password to netgear1.
- reset the router's address range to 192.168.0.x
- set up a 192.168.0.x static address temporarily on a PC, and then browse to http://192.168.0.2/admin and reset the NAS to use a static address that is compatible with your new network.
- NotreadyyetAspirant
No it uses192.168.1.x
That's why it doesn't work. Someone assigned a static address to the NAS that worked with your old network but which isn't compatible with your new network.
The three ways to fix this are above. The simplest is to reconfigure the router to use 192.168.0.x
