Bogga
Mar 20, 2014Aspirant
HDD installation... am I doing it right?
So I'm very new to this NAS-thing and I honestly don't know Jack Schitt... In my media computer I had two 3TB-drives and one 2TB-drive. I bought a NetGear ReadyNAS 104 and one more 3TB-drive... ...
Mar 20, 2014Guru - Experienced User
Did you do a factory reset after you copied the movies to the NAS? If so, you already lost the files you copied.
With XRAID2, the disks you add need to be at least as big as the largest disk in the array. That means you can't add the 2 TB drive into your existing array (though you could use it if you do another factory reset).
