yoh-dah
Dec 10, 2004Guide
HDTV recording options
The RAID 5-protected large-capacity ReadyNAS makes a perfect storage solution for HDTV recording. Available consumer-level HDTV DVRs currently don't have a standard network storage interface, so if y...
yoh-dah
Dec 04, 2005Guide
verden wrote: I have a comcast 6412 STB and Mac OS 10.4.3 - There is a free app called iRecord that will recognize the STB and allow you to schedule and record HDTV using the tuner. I recommend VLC for playback.
Hmmm, that's interesting. So you connect your Mac to the firewire port and run iRecord. Do you have to manually start and stop recordings from the Mac or can the Mac control changing the STB channels and do time-shift recording on its own?
