gponcho007
Apr 14, 2013Follower
HELP: Accidently Deleted Share on ReadyNas Duo
Hi, I accidently deleted my share (media) on my ReadyNas Duo. Is there any way to retrieve it? I have read some older posts however nothing seems to have been updated since 2008. Has there been a...
de_niro
Apr 14, 2013Guide
first you need to make sure that your volume is mounted as EXT2,if so,there is way to recover deleted data using e2undel tools
http://manpages.ubuntu.com/manpages/har ... del.8.html
all you need to do is plugging an USB storage and issuing the command as below.
install apt.bin addon
http://www.readynas.com/download/addons ... PT_1.0.bin
apt-get update
apt-get install e2undel
e2undel -d /dev/c/c -s /USB_HDD**
apt-get update
