LucianoBrentana
Mar 21, 2016Aspirant
Help for home folders and sharing connections
Good morning, i hope that some guru here can help me, because after a lot of search i was not able to find a solution. I have a READYNAS 102 OS 6.4.2, FlexyRaid Nas has 1 user, XXX Nas has 3 shared fo...
- Mar 22, 2016
Hi LucianoBrentana,
I just tested it and it seems like the phone uses SMB for LAN server access to the ReadyNAS. I got the same behavior (which is normal; same with PC or Windows) just like what you have experienced. The contents or the folders won't be accessible if permission is set on the said share (folder) or if anonymous access is not enabled.
Kind regards,
BrianL
NETGEAR Community Team
BrianL2
Mar 21, 2016NETGEAR Employee Retired
Hi LucianoBrentana,
Welcome to the community!
What are the file sharing protocols enabled in your ReadyNAS? With regard to disabling home share, kindly check this article.
Kind regards,
BrianL
LucianoBrentana
Mar 22, 2016Aspirant
Hello Brian, many thanks. I had the NAS set for Italian Language, and there the Home Folder seemed to me like something of administration, so i didn't touch anything. Setup for English, it's now ckear, anything disabled and no more access, thanks. About protocol, there are enabled just DLNA and SMB regards, mario
- BrianL2Mar 22, 2016NETGEAR Employee Retired
Hi LucianoBrentana,
Kind regards,
BrianL
NETGEAR Community Team- LucianoBrentanaMar 23, 2016AspirantHallo BrianL, thanks for all your help, Luciano
