lagule
Aug 19, 2021Tutor
Help for upgrade RNDP6310-200 - Bios and OS
Hello everyone, I am French and owner of an RNDP6310-200 with 6x3TB in X-RAID. My bios is: 08/20/2008 FLAME6-MB V1.5 Is an update possible? Do you have functional links? How to update this Bios? ...
karenlarson
Aug 19, 2021Aspirant
Aug 19, 2021Guru - Experienced User
Install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS.
- laguleAug 19, 2021Tutor
Link out:(
Sorry but my browser was involved!
Download is ok.
For the upgrade to OS6 do you have a link?
Thank you- StephenBAug 20, 2021Guru - Experienced User
If you do decide to convert the Pro, then you should increase the RAM. Shipping OS-6 NAS have at least 2 GB of RAM, your Pro only has 1 GB. It might work, but some here have run into out-of-memory crashes after the conversion. The upgrade is inexpensive, and is simple to do.
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Optionally: Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
- laguleAug 21, 2021Tutor
Salvation!
Back to the situation and a big thank you my friend!
Bios 2010 installed, Ram 3go installed and OS 6.10.5 which works perfectly.
Last question before the closing of the subject, do you know which processor I could install to gain in performance (especially for PLEX).
Thank you
