JCEW
Mar 20, 2011Aspirant
HELP: HD movies stuttering when playing from ReadyNAS Pro ??
Hello, So sad, I am getting really frustrated. :? I purchased a new high performance HTPC with Windows7 (for running Media Center), PowerDVD10 and a ReadyNAS Pro to watch and archive my HD movie...
JCEW
Mar 27, 2011Aspirant
solo8788 wrote: You should rule out the router/switch, have you tried a direct connection?
http://www.readynas.com/forum/viewtopic.php?f=21&t=35583
Thank You. May be I did not get the point...
I have a Netgear unmanaged Gbit switch, which is connected to the HTPC (living room) and the ReadyNAS (other room). Where do I "rule out" the switch? ...another cable is not possible as I can not put another cable throughout the rooms...
Please advise, thanks, JAN
