JCEW
Mar 20, 2011Aspirant
HELP: HD movies stuttering when playing from ReadyNAS Pro ??
Hello, So sad, I am getting really frustrated. :? I purchased a new high performance HTPC with Windows7 (for running Media Center), PowerDVD10 and a ReadyNAS Pro to watch and archive my HD movie...
JCEW
Apr 07, 2011Aspirant
victorhortaliveson wrote: The new 4.2.16 seems to have improved things.
I'm running a backup up now between the 2x ProPioneers and I'm getting a smoothish datarate trace with 70MBps or so upstream and 70MBps downstream.
This is a lot better than previous.
Thanks for making me believe that there might be some light at the end of the tunnel :wink:
Are you able to test playing/streaming HD movies with the movie file stored on the NAS and played on the W7 client by MSFT MediaPlayer or MCE? When copying files from NAS (CIFS) to the W7 client the datastream here is showing 60MBps. CIFS absolute speed appears not the problem, it seems to something to with streaming HD movies (which require higher variable bandwith on demand)...or so...
AFAIK there is no way back from 4.2.16 to 4.2.15, therefore I want to be 100% sure the problem is solved before upgrading...after 4.2.16 has been released...
/Jan
