Strange_alex's avatar
Strange_alex
Help. I think my ReadyNas Ultra6 is dying.
One day I did not find access to the storage. Looked at the NAS, it was not working, only blinking both LEDs. I turned it off, blew out the dust inside, and turned it back on. It was also blinking and wouldn't turn on. Every 5-6 seconds the green and blue LEDs light up at the same time for a very short time, and if you look behind the back wall, there is an attempt to spin the blades of both fans (they twitch) at the same moment when the LEDs blink. After some time of such attempts, the booting process starts and even succeeds. The device starts synchronization of disks. But since I have 6 disks in Raid5 mode, and everything is filled with 80%, this process is not fast, and should take several hours, I can't keep track of it online. After some time, when I again pay attention to the device, it also blinks and does not turn on.
What can it be and how to fix it?
  • I agree this sounds like a power supply issue.  While the volume is in re-sync, you should do nothing.  But I hope you have a recent backup, as it could fail during re-sync in a way that makes the volume inaccessible.
    Once the re-sync is complete, you can try booting the NAS with no drives.  It's not a great test, but can be useful in some cases.  If it boots more normally (up to the point of saying "no disks", of course), then that's another hint it is the supply.
    If you have a spare ATX12V power supply (or one you can "borrow" from a PC), you can connect it externally just to see if that fixes it before you invest in a replacement supply.
  • StephenB's avatar
    Do you know what firmware you are running?
    The amount of data in the volume does not affect the resync time.  Resync requires every sector of every disk to be either read or written, even if the volume is empty.
    This sounds like something is failing - perhaps the power supply (which can be replaced).  Do you have a backup of the data?
    I'm tagging Sandshark , as he might have some suggestions on troubleshooting.
    • Sandshark's avatar
      Sandshark
      Sensei
      • Strange_alex's avatar
        Strange_alex
        Yesterday, I found a 20TB drive and started backing up just as I was syncing. Since I have a lot of shares, and I didn't want to copy several streams in parallel, the NAS stayed half a night without load and.... did not reboot. Although earlier, judging by the output of the 'last' command, it could reboot every few minutes. Just in case I stopped the tailscale daemon beforehand, which shouldn't affect it in any way, but the fact remains - no reboots yet.
        Problems with the power supply are the main theory so far, I will look for a replacement. Might be worth taking it out and checking for blown capacitors. As soon as I copy the contents - I will try booting without disks as you advised.
        Any other tests to check the power supply? I find it a bit strange that it reboots without load, but under load it is stable.
        Does the blinking lights mean anything? Is it just a side effect of the disks not getting enough power to start?
ProSupport for Business
