horak
Feb 13, 2015Aspirant
Help me save my data
Hi, I have recently (16 nd December) upgrraded firmware from 6.1.9 to 6.2.0 and I"m having some issues with it. My HW: - ReadyNAS31400 is occupied with 2x HDD WD4001FAEX (4TB / SATA / 64MB CACH...
Nhellie
Feb 13, 2015Virtuoso
It's risky if you don't have back up. What I'd do is to check the drives first using disk diagnostic tools (Seatools or WD Lifeguard), if both of the disk are okay, I'd put one of the drives on the original bay where it was previously inserted then perform an OS reinstall.
But if you are not sure to do the stuff I mentioned, it is best to call support:
http://support.netgear.com/general/contact/#tab-call
