golfo1234
Jan 25, 2016Follower
HELP my readynas duo its NO FIRMWARE INSIDE
PLEASE i need help for install a firmware by usb front. i lost the firmware. the reayd nas is blow all ligths when starts raidar dont connect. the reset in back side dont fix a problem i need ins...
Jan 25, 2016Guru - Experienced User
Do you know if this is a duo v1 or a duo v2? Please review this guide before answering: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
I suggest powering down, and removing the disks (labeling them by slot number).
Then power up, and see what happens. Normally RAIDar would connect, and tell you that there are no disks.
BrianL2
Jan 25, 2016NETGEAR Employee Retired
Hi golfo1234,
Welcome to the community!
In addition to StephenBs suggestion, you can also do a direct connect procedure to check if the ReadyNAS hardware is still okay.
Kind regards,
BrianL
NETGEAR Community Team
- StephenBJan 25, 2016Guru - Experienced User
The first step (removing disks, and powering up) is intended to let you know if the NAS hardware (and flash) are ok - or if the problem is related to the disks.
Brian's suggestion needs to be done with the disks inserted, and should be a second step. It is intended to rule out a problem on your network.
Once we know both outcomes and the model information, we'll have a better idea on the next steps.
Do you have a backup of your NAS?
