golfo1234
Jan 25, 2016Follower
HELP my readynas duo its NO FIRMWARE INSIDE
PLEASE i need help for install a firmware by usb front. i lost the firmware. the reayd nas is blow all ligths when starts raidar dont connect. the reset in back side dont fix a problem i need ins...
BrianL2
Jan 25, 2016NETGEAR Employee Retired
Hi golfo1234,
Welcome to the community!
In addition to StephenBs suggestion, you can also do a direct connect procedure to check if the ReadyNAS hardware is still okay.
Kind regards,
BrianL
NETGEAR Community Team
Jan 25, 2016Guru - Experienced User
The first step (removing disks, and powering up) is intended to let you know if the NAS hardware (and flash) are ok - or if the problem is related to the disks.
Brian's suggestion needs to be done with the disks inserted, and should be a second step. It is intended to rule out a problem on your network.
Once we know both outcomes and the model information, we'll have a better idea on the next steps.
Do you have a backup of your NAS?
