flip68
Jan 25, 2017Aspirant
Help Needed...ReadyNAS Pro 6 booting very slowly
I need some assistance to confirm what is happening. I have a ReadyNAS Pro Pioneer edition that was running 6.6.0 for a long time with no issues. I recently upgraded to 6.6.1 and it seemed to ha...
flip68
Jan 26, 2017Aspirant
Well i finally decided to just power down the NAS and reboot it to the BOOT MENU, I selected SKIP VOLUME CHECK and it booted successfully with no apparent problems.
My files in all my shares appear to be fine and I launched RAIDAR and it shows the following. I clicked diagnostics and got the following below although I'm not sure how to interpret it.
I also downloaded the log files and am not sure how to send them to you for a possible quick review of what might have happened?
Thanks!
Jan 26, 2017Guru - Experienced User
/home should be empty, so something is certainly wrong there.
Do you have ssh enabled?
