kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
mdgm-ntgr
May 13, 2012NETGEAR Employee Retired
Get a Wireless N router. You can either bridge your existing router with something like the WNDR3700 or if you have a modem/router all in one replace that with one that has wireless n.
The benefit of getting a wireless n router with gigabit ethernet is that you can connect your NAS to that via a Cat5e or newer ethernet cable and a client PC to it also via ethernet for when you want very fast file transfer speeds.
