kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
kunalraiker
mdgm wrote: Can it connect via wireless N or gigabit ethernet? If not, probably not.
Don't think so.
Wireless interface
True 802.11g wireless networking
Support for 802.11b and 802.11g routers and access points
Throughput up to 54 Mbps, high speed PCI interface to radio module
One-touch setup (with compatible WPS-supporting routers)
Supports WPA Personal, WPA-2AES, and 64/128-bit WEP encryption
Ethernet interface
Shielded CAT5 RJ-45 connector
Connects to any 100 Mbps or 10 Mbps network (with Auto MDX)
