kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
kunalraiker
May 14, 2012Aspirant
StephenB wrote: Perhaps. The WNDR3800 is much faster than your current router. But if your laptop hardware is also 802.11g then it won't be any faster. Can you tell what WiFi card is installed in the laptop?
kunalraiker wrote: Can I expect better results using Netgear WNDR3800 Wireless Dual Band N600 Gigabit Router.
One netbook has a broadcom wireless adapter which is capable of N draft, the other laptop is more robust and decent spec has a n adapter (not sure what brand it is)802.11G has several channels (11 in the US). Your router picks one to use.
kunalraiker wrote: Also what does it mean by "WiFi Channel"
