kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
May 14, 2012Guru - Experienced User
Then upgrading the router would speed things up - 2x perhaps (depending on what hardware you have).
kunalraiker wrote: One netbook has a broadcom wireless adapter which is capable of N draft, the other laptop is more robust and decent spec has a n adapter (not sure what brand it is)
Using ethernet would be faster still, so if you have a lot of transferring to do it is worth hooking up the cable.
