kunalraiker
May 13, 2012Aspirant
HELP....NEW NOVICE USER SPEED ISSUES READYNAS DUO
Hi, I'am getting average 2 MB/S transfer rate, the Access point used is linksys WAP54G ( with latest firmware) and modem is Tenda 840R ( did update the firmware once, probably on updated firmware)....
May 15, 2012Guru - Experienced User
Understood. Though if you have a lot of data to move, you can get 10x the speeds over ethernet. So it could be worth the inconvenience of going down to the first floor. Just a thought.
kunalraiker wrote: I don't have the comfort of ethernet ports as I have a multi level townhouse and the router is connected on the first floor, whereas the rest of the equipement (laptops and squeezebox touch) are on the top floor.
